Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Renault
Megane
Brakes
Rotor
Replace/Remove
2004 Renault Megane Rear brake disc replacement
2004 RENAULT MEGANE
43,000 MILES • 4 CYL • FWD • MANUAL
WHEELERDEALER
MEMBER
1 POST
FOLLOW
Can you advise me on the procedure for correctly adjusting the rear wheel bearing which comes as part of the brake disc
Jun 27, 2008 at 5:03 AM
KHLOW2008
CERTIFIED EXPERT
Hi wheelerdealer,
The bearing unit is to be torqued at 45 ft/lbs.
No adjustment necessary as the spindle is fixed length.
Jul 6, 2008 at 8:43 AM
