2004 Renault Megane Megane Driver Window not working
2004 RENAULT MEGANE
RWALDRON
Electrical problem
2004 Renault Megane
Hiya guys.
Firstly , great website, loving your work..
I have a renault megane 2004.Last year the passenger window would not go down.then a few months later it just started to work.
Now the driver side window will not go down.
When I click the button I don't hear any movement at all from the window.Does this mean it is or is not the Window regulator.
I have checked the fuses and they seem ok.
Someone suggested removing the fuses and then deadbolting the locks and unlocking..
I just don't want to go down the road of replacing the regulator if there is a simple little trick you might have come across..
Its a very common problem with meganes..
Any help please
Ray..
Feb 17, 2009 at 11:14 AM
DAVE H
  • 13,384 POSTS
All the renault series of vehicle's have a problem with the wiring connectors .. I would be removing the door panel and checking the connector to the motor ..check it is secure and that the wires which lead back through the door to the fuse box are not broken or chaffed in any way .. whilst you have the panel removed use a voltmeter to check you have power and ground/earth going to the motor when pressing the button !!
Feb 18, 2009 at 10:00 AM
