2001 Renault Megane Tail Lights
2001 RENAULT MEGANE
82,000 MILES • 4 CYL • FWD • MANUAL
ECRUM08
Hi, my problem is quite complicated. I’m having terrible problems with all the light at the back of the car. Firstly, when I press the brakes the rear fog lights come on and both indicator lights but not the brake lights. If I activate the indicators (left or right) the rear fog lights flash with them. If I activate the indicators and step on the brake the rear fog light flashes in time with the indicators, indicator Lights don’t flash and the whole lot flash double time (is if an indicator bulb has blown). All this is also linked to the rear windscreen wiper. When I have the front wipers on and I step on the brake the rear wiper activates. All the rear lights are affected, fogs, brake, reverse and indicators and there are too many combinations to list all. It all started when I noticed that when I had the lights on and stepped on the brake I noticed the rear fog light indicator on the dash flash briefly and it steadily got worse.
Feb 4, 2010 at 4:06 AM
KHLOW2008
  • 41,814 POSTS
Hi ecrum08,
Thank you for the donation.
The symptoms described seems to indicate a fault with the ground circuits.
Our database does not have any information on this vehice so I can only advise how to go about doing it and you would have to locate possible connections and components.
At rear of vehicle, check all ground circuits, clean and retighten them and retest.
Check the front groun connections as well, not only the main from the battery negative but also from the engine wireharness to body.
If you had done any body or paintwork repairs, check those sections first.
Feb 6, 2010 at 9:04 PM
