Brakes problem
1999 Renault Megane 4 cyl Front Wheel Drive Manual
After changing out the drive shaft and wheel bearing, and re-connecting everything as it was before, the ABS warning light is on. Nothing was disturbed or appeared to be broken. Other than replacing the ABS wire--which is quite expensive--what else can I do to check out this fault?
Aug 7, 2008 at 12:42 PM
