1998 Renault Megane starter relay
1998 RENAULT MEGANE
110,000 MILES • 4 CYL • 2WD • MANUAL
JJ1989
the starter relay is tickin and there is no poer going to the fuel pump, i have had the fuel pump tested off the car and it is fine. the car turns over but wont start. any suggestions will be greatly appreciated>
Mar 12, 2010 at 3:30 PM
DAVE H
  • 13,384 POSTS
is the immoboliser light on the dash display flashing fast ?
Mar 14, 2010 at 5:41 AM
JJ1989
no the immobiliser is normal. thanks for the reply any other ideas?
Mar 15, 2010 at 6:34 AM
DAVE H
  • 13,384 POSTS
you probably already done this but ...check fuel pump fuse and replace the relay .. check for hot/live feed to fuel pump wiring connector @ ignition on and @ cranking using a multimeter ..if you have a live feed the pump is bad, after engine has started the PCM controls fuel pump via fuse and relay .. is the check engine light on ? are there any fault codes stored on the cars computer ? Let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1059.png
Mar 15, 2010 at 4:58 PM
