1998 Renault Megane Megane engine cuts out
1998 RENAULT MEGANE
LENSONT
Engine Mechanical problem
1998 Renault Megane 4 cyl Manual
Hi there, my megane cut out a couple days ago along the link road going at 60mph and wouldnt restart. The eginition works and the battery seems fine, but when its started the and the engine starts it can be reved for a few seconds then seems to fight with the engine and cuts out.
After that the engine doesnt start up at all.
Any ideas on this would be greatly appericiated.
Jan 29, 2009 at 4:52 AM
DAVE H
  • 13,384 POSTS
is there a little red light on the dash flashing constantly .. if so, your immoboliser has been set (not an uncommon fault) is the key fob working correctly ?
Jan 29, 2009 at 5:08 AM
LENSONT
No theres no flashing light, and the key works fine
Jan 29, 2009 at 5:14 AM
DAVE H
  • 13,384 POSTS
you will need to check the fuel pump is getting power when ignition is cranking ? sounds like your getting fuel @initial key ON ... but no fuel being pumped while cranking .. the fuel pump and wiring is under a the back seat under a black plastic round cover !
Jan 29, 2009 at 5:54 AM
LENSONT
I had a look at that, its all connected tightly. The revs from the engine spike badly when it trys to start.
Jan 29, 2009 at 7:12 AM
DAVE H
  • 13,384 POSTS
I do not understand what you are saying it is doing ... go inti a litttle more detail for me ?
Jan 29, 2009 at 5:43 PM
