immobilizer, car will not start
1998 RENAULT MEGANE
180,000 MILES • 1.6L • 2WD • MANUAL
RIJOWC
  • 5 POSTS
Need help please or i will have to scrap the car.
Have the car for 5 month no problems, one day the electrical problem light begins blinking when driving (the square with zig-zag) if the car is under 1.5rps and the turn switch no working…
So I shut down the car and it won’t start again, the el. problem light is blinking there is no red light (immobilizer ) so the car key doesn’t work (ir key). Car has contact but the radio and light are the only thing working. I have done the the trick with the fuse and the car turn on one more time so i drove it to mechanic… no luck after that the fuse trick doesn’t work any more.
My mechanics have no idea what to do next, and has given up on it… any aides relay thankful i am comply broke any diy solution to.
Jan 9, 2020 at 9:56 AM
I would see if another key would work. if not lets do a hard system reboot. remove the negative battery cable and hold it to the positive battery terminal for 1 minute this will discharge the capacitors and let the system reboot. here is a guide to help us as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jan 10, 2020 at 10:45 AM
RIJOWC
  • 5 POSTS
Hi Ken,
Thank you for the reply, the second key does not work.
I read about the hard system reboot and have found that there might be a problem with when doing so with the older models of cars with as you must readopt the throttle body...
i cant find information for Megane 1998, do you maybe have that information?
thanks in advance and have a nice day.
Jan 13, 2020 at 8:47 AM
We only have info for US cars which some parse over but not Megane . I can help in any other way we can. The throttle body will relearn so that should not be an issue. Let me know what happens.
Jan 13, 2020 at 12:41 PM
RIJOWC
  • 5 POSTS
Will do later today, will let you know all together have nothing to lose as the car is not functioning anyway.
Jan 14, 2020 at 1:05 AM
RIJOWC
  • 5 POSTS
I did not fix the problem. I even do a wire jumper and had it on for 20 minutes.
Jan 14, 2020 at 10:00 AM
let's run a scan to see what codes come up. here is a guide:
Jan 15, 2020 at 11:11 AM
RIJOWC
  • 5 POSTS
Hi Ken,
we have tried, but the error is not specific is just says sometihng like electrical problem. no extra specifics.
Jan 17, 2020 at 1:43 AM
Lets check the car fuses. here is a guide to help make sure the key is on:
Jan 18, 2020 at 10:06 AM
