1997 Renault Megane Change the antifreeze
1997 RENAULT MEGANE
71,000 MILES • 4 CYL • FWD • MANUAL
MIRON
Could you explain breafly how to drain out the antifreeze from the engine. The car is Renault Megane with 1.6 L petrol engine. Thanks.
May 4, 2008 at 8:27 AM
DAVE H
  • 13,384 POSTS
remove the filler cap from coolant tank .. and remove bottom hose off radiator and let the coolant drain .. when refilling take out both bleed screws from top hoses and fill to bottom screw when water comes out steady replace screw and do the same on top bleedscrew then top up coolant to correct level !
Feb 26, 2009 at 10:35 AM
