2003 Renault Laguna Renault Laguna 1.9dci Tourer
2003 RENAULT LAGUNA
PFLATMAN
Noises problem
2003 Renault Laguna Two Wheel Drive Manual 140000 miles
I have a noise which seems to come from the front left/under bonnet area. It only happens in 3rd and 4th gears, when applying the throttle, and at 2000 to 2500 revs. It goes away when I back off the gas or depress the clutch. The noise is a rattling/grating kind of noise like something is in contact with something it should not be.
I can feel no noticeable reduction in performance or gear change or clutch operation, nor is there any vibration or strange feeling that I can feel through the gear change, throttle, or clutch pedal.
Any guidance would be gratefully received.
Regards, Peter
Aug 5, 2008 at 1:52 PM
DAVE H
  • 13,384 POSTS
you will a tech to test drive and try to locate the fault ..usually garages do not charge for a diagnosis in the hope they will get the work ..
Mar 21, 2009 at 9:07 AM
BELTY17
Hello Peter I was wondering if you found the problem with gears in 3rd and 4th as I have the same fault ??
Regards John ..
Mar 28, 2012 at 7:56 AM
