2002 Renault Laguna laguna knocking noise rattle rear
2002 RENAULT LAGUNA
WAYNE14280
Noises problem
2002 Renault Laguna 4 cyl Two Wheel Drive Manual
still cant find where knocking noise is coming from at the front left somewhere checked shocks springs its had new drop links new track rod ends new rack ends bottom arms look newish???...other problem there is a rattle noise coming from the rear somewhere sounds bit like when the exhaust hest sheilds loose but thats all fine and when i go over bumps or potholes the back end hops about etc jacked rear up today checked the rear shocks and at the top where the bolt goes through i can sort of move it slightly from side to side if i wigle it thats the same on both sides do need new shocks no idea about subframe bushes i know they arent cheap any way i can check these to see if they are naffed no play in rear wheels when standing or jacked as iv grabbed on them tugged them up and down side to side etc
Jun 21, 2010 at 12:34 PM
DAVE H
  • 13,384 POSTS
check for worn suspension strut top mountings
Jun 22, 2010 at 1:36 AM
