2001 Renault Laguna lost reverse gear
2001 RENAULT LAGUNA
127,000 MILES • 4 CYL • FWD • MANUAL
LES NEWSOME
I recently stalled the car while reversing up hill its stopped with a thump the car has always shuddered while reversing uphill, all forward gears are working fine when you select reverse and let the clutch up the gear box just grinds as if it was not properly in gear any idea what could be wrong !!! Les
Mar 22, 2009 at 5:35 PM
DAVE H
  • 13,384 POSTS
you need to have the gearbox inspected i'm afraid .. it is not engaging reverse correctly inside the gearbox ... you could check the gear linkages on top the gearbox under the bonnet to be sure !!
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_374.png
Mar 23, 2009 at 4:02 PM
