1994 Renault Espace Fuel Diesel
1994 RENAULT ESPACE
126,678 MILES • 4 CYL • FWD • MANUAL
GEORGE PEACH
I'm Having trouble with what seem's to be air
in the Fuel Line, When Starting I have to crank
the engine and then it will start on the 2 try
even when the engine is hot,The engine as
also cut out when easing back but as started
again with no promblem.
(I have changed and primed the filter),
I was wondering if the trouble lies in the pump?
as the pipe from the tank to the filter seems to be clear of any air, But the return pipe from the pump to the tank seems to have excessive air?.
Sep 16, 2008 at 7:15 AM
DAVE H
  • 13,384 POSTS
check the line connectors for leaks . they may be allowing air into the system !!
Mar 17, 2009 at 9:43 PM
