Engine Mechanical problem
2002 Renault Clio 4 cyl Manual 84700 miles
had my clio for just over 4 months and over the weekend the car started to judder and loose power when driving and very low revs, went to local garage to have diog check and it came back with 2 faults 1 being a new crank shaft sensor needed and the other was air con (which i dont have) not been in accident as guy checked to see if it (air con) had been taken out. prob ok until 2 days after then started to judder and lose power again only worse so took it back and 1 fault a new lumbar sensor so had that done. 2 days later same problem has started engine management light is on and car occasionally loses power cant afford to keep going down. Help please
May 19, 2010 at 11:15 AM
