When I turn the key the speedo needle vibrates but nothing else happens?
2002 RENAULT CLIO
49,000 MILES • 4 CYL • 2WD • MANUAL
MBIALYJ
im having problems starting my clio sport. when i turn the key the speedo needle vibrates but nothing else happens. it wont even turn over.any ideas what this could be. i also tried jump leads because i thought it could be the batt. but the same thing happend. cheers
Dec 16, 2007 at 7:55 AM
DAVE H
  • 13,384 POSTS
It is a battery fault .. try some better grade jump leads .. or replace the battery ..
Mar 17, 2009 at 10:21 AM
Yep, I agree with DAVE H, this sounds like a battery problem, here is a load test guide for the battery which you can use to confirm the issue.
Oct 30, 2024 at 6:16 PM
