to debug, I have unmounted the electric engine from the window lifter mechanic, it works only in one way (UP) and does not work down way
plugged out the motor, and with multimeter I could messaure only 12 volt when pressing windo UP switch, and 0 volt when pressing Down switch
The same situation from the left door's contorl switch.
I have unmounted the right window's control switch, it is working OK.
Does this window lifting has somewhere a relay? controller? Or fuse?
Aug 8, 2010 at 12:25 PM
