2000 Renault Clio horn
2000 RENAULT CLIO
55,000 MILES • 6 CYL • FWD • MANUAL
BERYL
Can you please tell me as to why the horn isnt working on my clio....might it be a fuse problem? and if so does it tell you in the fuse compartment as to which fuse it is as it dosn't say in the handbook
Jul 14, 2010 at 9:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
unfortunately i don't have access to much info. on renaults, but the diagnosis for the horn is pretty much the same for all vehicles. first start with the fuses (since not sure which one, just check them all with a tester, quick and easy), if fuses good then test the horn relay. if relay and fuse is good then test for power at the horn. if its not getting power then switch on steering wheel is probably at fault, if power is at horn but not sounding then horn itself needs replaced.
Jul 14, 2010 at 3:07 PM
