You may find this video helpful, it is not your exact vehicle but the principles are the same for most vehicle.. the 2 top transmission to engine bolts are the hardest but are removed in the same way the video describes..
Hope this helps with your repair. Please keep us updated on your repair outcome and do not hesitate to contact us again for further information or assistance.
And please keep us updated on all your repairs.
Thanks, Dave H
Feb 25, 2021 at 12:01 PM
DAVEH429
CERTIFIED EXPERT
Hello.
Attached are the actual removal procedures, hope this helps.
Thanks for using 2CarPros.
Dave. ~H~
Mar 1, 2021 at 4:59 AM
FLIGHTCOMMANDER
MEMBER
how do you get to the 3 top bolts that release the motor from the transmission. i am replacing engine but did not want to pull tranny. do you have to remove both together then separate or is there a secret jaguar trick. thanks, bill
Mar 10, 2021 at 7:01 PM
(Merged)
MHPAUTOS
CERTIFIED EXPERT
Hi there,
If you remove the tail shaft, cross member and selector, you can drop the back of the trans down enough to access the 3 top bolts with a long extension.
