Removing transfer case?
2003 CHEVROLET TRAILBLAZER
200,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
CORY2427
  • 293 POSTS
Bearing pulled out of transfer case when trying to remove axle took a puller to get axle out. just needing an easy way to remove it without taking rack pinion out or anything if possible.
May 27, 2025 at 5:46 PM
Axle? Do you mean drive shaft? Here is what we are working with, can you upload an image or a short video of what the problem is? Check out the images (below).
May 29, 2025 at 11:04 AM
CORY2427
  • 293 POSTS
Bearing came out and broke inside of differential where cv axle goes in
May 29, 2025 at 6:34 PM (Merged)
Can you upload an image of the problem?
May 30, 2025 at 9:51 AM
