Hey guys,
I need to replace the front cam seal, and to do that I need to remove the timing belt.
My question is, how do I remove and replace the timing belt on a 1999 Pajero with a 3.5l engine?
I believe there is a belt tensioner, so is it just a case of marking the belt and cam and crank, making sure the timing mark is aligned, then removing the tensioner, which will then need to be put in a vice to push it back, insert the pin to lock it in place.
Then, with the timing belt off, pull off the cam wheel? pop the old seal out, new seal in, cam wheel back on, timing belt on, tensioner on and then continue with the assembly of the rest?
Also, is there an easy way to get the belt back on or should it just slip back on?
Sorry about all the questions,
Rob
Rob
May 20, 2013 at 1:29 AM
