Am very close on removing the engine from the car. I have seen many videos and most say to support the transmission. Since these engines have studs coming out of them going into the transmission, it has to come out at a small angle. Would you just put a jack underneath the transmission and jack it up a bit along with lifting the motor? Or would you loosen the bolts on the transmission mounts to lift up the transmission freely when needed to separate them. My only concern is that loose song the transmission mount bolts may make the transmission move too freely and make it harder to separate the two, as everyone says its a PITA to separate them sometimes.
Aug 25, 2021 at 8:40 AM
