Removing seized driver side CV axle
2002 DODGE RAM
300,000 MILES
RICK FRIESEN
Tried everything to remove axle and it won't budge. is there any trick to it?
Feb 19, 2021 at 12:14 PM
Are you using an axle puller? There are many different types of these but I am sure you will need to use one. The manual has you use a slide hammer which in my opinion works the best.
https://www.2carpros.com/articles/replace-cv-axle
Below is the process from the manual but you can get a slide hammer from most any parts store that has a rental program. Let me know if you can't find one or have questions and we can go from there. Thanks
Feb 19, 2021 at 6:09 PM
