I have the car listed above with a Zetec Rocam 1.6 engine. The power steering pump has a small leak where the hydraulic fluid enters the pump. Before replacing the entire pump, I wanted to see if there was an o'ring or something that could be replaced, but I can't find a way to remove the plastic fitting where the feed line connects to the pump (marked with a red circle in the picture).
Does anyone know how to remove this plastic fitting? All the disassembly videos I found are for pumps with a metal fitting, not this plastic one.
May 31, 2025 at 9:17 AM
