How to remove PO717 code from dashboard
1996 CADILLAC ELDORADO
103,000 MILES • 4.3L • V8 • 2WD • AUTOMATIC
ROY ELMER
Service transmission light on how do you remove the code from dashboard?
Nov 30, 2016 at 7:51 PM
CARADIODOC
  • 34,306 POSTS
The best way is to erase it with a scanner once the cause has been solved. Given the age of the car, you can disconnect the negative battery cable for a minute, but be aware codes in some computers wont erase that way. I do not like to recommend that because people reading this while researching their car's problem might try it, and there are a lot of tricks built in to newer cars, especially GM products, that require trips to the dealer, often on a tow truck. European cars are famous for this too. Disconnecting the battery or running it dead should now be avoided whenever possible.
Nov 30, 2016 at 10:56 PM
