Oil pan gasket replacement?
2016 KIA RIO
107,000 MILES • 1.6L • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
need to replace the oil pan gasket. any instructions?
Dec 11, 2024 at 11:56 AM
Yep, first you must remove the under shield and then drain the engine oil, here are the instructions on how to change the oil pan gasket out. Check out the images (below). Let us know if you need anything else.
Dec 11, 2024 at 1:37 PM
