Removing and replacing the transfer case?
2016 RAM 1500
126,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JOEDUDE37
what tools and sockets will i need to remove and replace the transfer case? and what challenges might i encounter
Dec 20, 2025 at 7:04 AM
This job is not to bad, here is a video of the job being done on a similar truck but the procedure is the same, you will need two people or a transmission jack to support the transfer case once it is removed, they are heavy.
https://www.youtube.com/watch?v=1Bbvg_DRRow&pp=0gcJCTwKAYcqIYzv
Start on level ground, and block the tires, then remove the driveshafts, wiring and mounting bolts and you are all set. Are you rebuilding the 4x4 unit or installing a used one?
Dec 21, 2025 at 10:55 AM
JOEDUDE37
installing a used one.... are there any gaskets that i need to replace
Dec 22, 2025 at 11:58 AM
I think they just use silicone sealer between the transmission case and transfer case.
Dec 23, 2025 at 9:57 AM
