Remove ignition lock housing
1998 SATURN SC2
204,000 MILES
KSTEELE
  • 10 POSTS
I cant find any little buttons on the housing to unlock it!! I am trying to remove the tumbler that the key goes into and i can't figure out how to do it. All i can see is two little bolts on the end of it. Any suggestions?
Jul 14, 2019 at 5:45 PM
Welcome to 2CarPros.
Here are the directions for removal and replacement of the ignition lock cylinder. The attached pictures correlate with the directions,
________________________
IGNITION LOCK CYLINDER - REMOVAL
1. Disable the SIR system. (Refer to Disabling the SIR System in Diagrams/Diagnostic Aids/General Troubleshooting Procedures/The SIR System.) See: Vehicle > Diagnostic Aids
Ignition Switch: Removal
pic 1
2. Remove two screws holding Data Link Connector (DLC) to filler panels.
3. Remove the five steering column filler panel screws.
pic 2
4. Remove hood release cable from lever by releasing cable housing, then rotating cable downward to cutout.
5. Remove steering column filler panel.
pic 3
6. Remove two upper-to-lower steering column shroud screws and three lower steering column shroud-to-steering column screws.
7. Remove upper steering column shroud.
8. Insert ignition key into ignition lock cylinder and rotate ignition key to ACC position.
pic 4
9. Depress the square locking button on the top of the ignition lock cylinder module and slide ignition lock cylinder assembly from ignition lock cylinder.
Ignition Lock Cylinder - Installation
Vehicle Steering and Suspension Steering Steering Column Service and Repair Removal and Replacement Ignition Lock Cylinder - Installation
IGNITION LOCK CYLINDER - INSTALLATION
1. Position new ignition and start switch (P/N 21024682) to ignition module assembly and install two screws and tighten.
Torque: 2 - 3 Nm (18 - 27 in.lbs.)
2. Connect electrical connector to ignition and start switch.
Ignition Switch: Installation
pic 5
3. Position upper and lower steering column shrouds to steering column and install two upper-to-lower steering column shroud screws and three lower steering column shroud-to-steering column screws.
4. Install ignition lock cylinder into ignition module.
pic 6
5. Route hood release cable through I/P, then install hood release cable to lever.
pic 7
6. Install steering column filler panel and Data Link Connector (DLC).
7. Install and torque five screws.
Torque: 2.2 Nm (20 in.lbs.)
8. Turn ignition switch to LOCK position and remove key.
9. Enable the SIR system. (Refer to Enabling the SIR System in Diagrams/Diagnostic Aids/General Troubleshooting Procedures/The SIR System.) See: Vehicle > Diagnostic Aids
____________________________________________
Let me know if this helps or if you have other questions. Note: If you lost the key for the original lock assembly, let me know. There are different directions you need to follow.
Jul 14, 2019 at 8:44 PM
