Remove driver's power seat
1995 CHEVROLET BLAZER
130,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
PAPAW JERRY
The hot and ground wires have been pulled out of the chassis side power connector for the driver's side power seat. I cannot reach under the seat to reconnect them so I think I need to remove the seat. How do you remove the seat if it cannot move to expose the nuts? I cannot reach the wires to repair the plug. There are no exposed wires from the seat to attach leads to power the seat. It does not help the seat is in the full down position.
Jan 26, 2018 at 9:41 AM
Good morning.
Can you install a power and ground wire to the connector from and external power source to be able to access the bolts? You could set a battery on the floor and use jumper wires from the battery to the connector.
Jan 27, 2018 at 4:43 AM
This is a problem, you are going to need to get to the wires or try to unbolt the seat from the frame. There is no easy way of doing this.
Jan 29, 2018 at 11:42 AM
