remove and replace inner tie rod end
2002 NISSAN SENTRA
140,000 MILES
DEBORAH2
Need to know how to remove and replace the inner tie rod end on a 2002 Nissan Sentra car, 1.8 litre engine, Is there a collier pin that has to be removed before taking the old inner tie rod end out and do you have to use a sledge hammer to get the inner tie rod end out.
May 29, 2013 at 7:25 AM
WRENCHTECH
  • 20,761 POSTS
They make a special tool for removing them and it can be nearly impossible without it.
May 29, 2013 at 8:09 AM
WRENCHTECH
  • 20,761 POSTS
I was referring to the tie rod itself. You should be able to pry the pin out with a screwdriver.
May 29, 2013 at 8:11 AM
