It's not too bad to replace the timing belt, you just need to take your time and follow each step, start by draining the coolant and disconnecting the battery. It is best to replace the timing belt tensioner pulley because they go out often. They have you remove the timing belt pulleys I am not sure why I guess they can wear as well so check that. Here are the steps to replace the timing belt in the images below. Sometimes you will need to refresh the page to open the images. Sometimes this bug happens, we try to fix it. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Sep 26, 2022 at 3:48 PM
