Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Caravan
Brakes
ABS
Module
Replace/Remove
ABS unit bad; cannot access the rear of the ABS unit plug
2008 DODGE CARAVAN
165,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
TOPMACK
MEMBER
1 POST
FOLLOW
ABS unit bad; cannot access the rear of the ABS unit plug. Any suggestions on how to remove the plug from the engine compartment side?
May 5, 2017 at 5:46 AM
CERTIFIED EXPERT
You need to remove the HCU and brake module as a unit and then you will have access to the plug so that it releases.
Here is a guide as well that will help with this:
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Here are the instructions below for more detail on this. Let me know if you have questions on this. Thanks
Feb 21, 2021 at 1:36 PM
