9/25/21
Hello Joe and Ken, I could not find the reply button for this continuation of our dialog, so I started a new dialog.
I took the truck to a new dealer ship and this is what they found out.
9/24/21 word/f/safety
MELTON RAM DEALERSHIP: Andrew 918-341-1512 Richard 918-260-0197 LYNN RIGGS BL. CLAREMORE, OK. 74017
Dora is the warrantee manager who works with the service department:
Dora stated about the following:
All safety features are setup and on and working. Motion is needed for the front safety features to work. The rear facing features are working and motion is not needed but will work with motion as well.
PEB: Pedestrian Emergency Braking Will brake if there is motion sensed.
FCW/braking: Forward Collision Warning Plus with Active Braking Will brake if there is motion sensed.
Advanced Braking Assist will brake if there is motion sensed or if I am not applying heavy enough braking to stop in time of impact.
ACC: Adaptive Cruise Control In Level 1 SAFETY GROUP AJ1 not on this truck.
Rear cross path with braking will brake in time to avoid impact while going in reverse. It will work on motion or no motion. It will learn as it goes.
Park sense front and rear park-assist with stop not on this truck.
Tinting on brow and the topper on the truck do not interfere with safety features.
Which of these safety features would qualify for lemon law requirements? Did not discuss
Are there special forms or reports needed for lemon law requirements? Did not discuss
Incorrect Spare Tire Installed/ FMVSS 110 NHTSA # 21V698000 FCA US LLC’s # Y62 not for this truck's VIN. Visually, manually checked to see tire was correct for this truck.
Remote Start with Automatic Cooling Climate Control: A/C should be at last setting when I shut the truck off.
Dora further explained about the Remote Start and A/C not activating on its previous setting.
After showing Dora the Chrysler C. S. Technical # 80-100-21-REV.B, She showed her tech and they installed one of two updates to the radio (1 hour). This did not solve problem. Tech looked into the connections further and found two failed parts, a HVAC Module and a Blower Motor Control. They ordered parts.
The second update, by air satellite, should show up on my NAV screen by Oct 5th, 2021. Install it and see if it works. If it does not work or no notification, call Dora. Dora said the Tech and her do not believe it will work to solve the problem either.
If parts are on a long backorder time Dora will call me and tell me a Customer care
number to call and tell them I want to start a case due to long back order time. (dealership is not allowed to start a case). This will prompt them to call Dora and let her know where she can get the parts from, in short order. Dora (or Tila) will then schedule me in for a couple of days to run a half days tests on the truck and install the parts. She will schedule a free rental car for me while they are testing and installing the parts and testing to see if the problem is solved.
It seems they did a very good through job and we will see how the parts are found, installed and tested in a timely manner. Thanks again for listening and suggesting fixes for these problems.
Sep 27, 2021 at 6:47 PM
(Merged)
