remanufactured engine replacement
1994 CHEVROLET BLAZER
307,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MIKETOSIS
i am looking to restore this vehicle by replacing it with a brand new engine and transmission. My question is since my car has over 300,000 miles of wear and tear what other components under the hood i.e, power steering, water pump, radiator, should i also replace as well?
May 7, 2016 at 7:49 PM
HMAC300
  • 48,601 POSTS
a water pump for sure otherwise it is totally up to you.
May 8, 2016 at 10:17 AM
Yes all of the above, basically everything that is a normal wear item should be replaced even the fuel pump.
May 9, 2016 at 11:25 AM
MIKETOSIS
thanks for the replies guys, can you make a list of everything that would be considered normal wear and tear please. thank you
May 15, 2016 at 10:23 AM
This is what I would do,
water pump
fuel pump
fuel pump relay
power steering pump
Ignition coil
Ignition module
plugs
plug wires
Ignition switch
radiator
radiator hoses
heater hoses
thermostat
serpentine belt
belt tensioner
alternator
battery
starter
That should do it, please let us know how it goes.
Best, Ken
May 15, 2016 at 10:29 AM
MIKETOSIS
thank you ken. you have been very informative. appreciate the advice
May 15, 2016 at 11:02 AM
That's what we are here for, please use 2CarPros anytime we are happy to help.
May 15, 2016 at 2:10 PM
