Where is the best to install a relay for trying to boost the remote turn on wire signal from head unit for a second amp?
2000 HOLDEN COMMODORE
355,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
2STONEY
  • 25 POSTS
I'm just wondering where about is the best to install a relay for trying to boost the remote turn on wire signal from head unit for a second amp? For example, closer to the head unit or closer to the first amp or between amp 1 and amp 2 or where? Cheers
Jun 21, 2024 at 2:52 AM
The relay should be wired so the main power wire is the main circuit, you can have it anywhere that makes sense.
Here is a video that will help you:
https://youtu.be/QFeUkXwmoXA?si=43dVq-_z_mKe2x0U
Please upload pictures or videos in your response to any problems so we can see what to help you with.
Jun 21, 2024 at 10:40 AM
