Relay for headlamps
1999 BUICK REGAL
115,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
PCULQUI
  • 354 POSTS
is there a separate relay for the main headlamps and a separate relay for the high beams? Also, is there a separate fuse for each of these headlamps?
Aug 27, 2020 at 6:54 PM
There is not. I attached the wiring diagram and the close view with the low and high beams highlighted. The high beams are run off the fog relay and there is a separate fuse for the left and right headlamps.
Let me know if there is anything else you need. Thanks
Aug 27, 2020 at 7:20 PM
PCULQUI
  • 354 POSTS
where was the fuse box be to check the 15A fuse for the low beam headlamps?
Aug 28, 2020 at 1:21 PM
It is in the underhood fuse box. I attached the information for this fuse box.
Aug 28, 2020 at 7:09 PM
PCULQUI
  • 354 POSTS
Okay, thanks.
Aug 30, 2020 at 12:47 PM
You are welcome. Talk to you next time. Thanks
Aug 30, 2020 at 7:40 PM
