Accidently added diesel fuel to my gasoline tank, now there is no spark and fuel pump will not engage, can I get a relay diagram?
2018 JEEP COMPASS
35,000 MILES • 2.4L • 4WD • AUTOMATIC
MISSZEE
MEMBER
FOLLOW
I just need a relay diagram for the vehicle listed above. I've looked everywhere and can't find it online or in the manual.
Jul 20, 2022 at 11:36 PM
BORIS K
CERTIFIED EXPERT
Please see below images.
Hope this helps.
Cheers, Boris
Jul 21, 2022 at 9:25 AM
MISSZEE
MEMBER
So, I accidentally put diesel in my gas car and drove it. Then I drained it out and replaced it with gas and octane boost. now there's no spark and fuel pump won't engage. so, it cranks but won't turn over.
Jul 21, 2022 at 9:41 AM
MISSZEE
MEMBER
I thought to jump start the fuel pump but there's no spark to ignite the engine.
Jul 21, 2022 at 9:42 AM
BORIS K
CERTIFIED EXPERT
How did you drain the fuel tank and associated fuel system?
Have the spark plugs been replaced? These would be fouled up with diesel as the engine had been running with the incorrect fuel.
Also, please check fuse F21, 15A in PDC (fuel pump) and fuse 23, 10A in TIPM (ignition coils).
