This morning I went to drive to work and when I opened the door, I discovered that my HVAC blower was on. There was a faint humming nose from under the dash as well. I started the engine and runs with no problem. I can turn off the blower and the A/C at the HVAC panel. But, with the key off, i am still able to turn the A/C and blower on. This shouldn't happen and has never happened before. No work has been done to the vehicle recently that would involve anything like that.
Last night it rained really hard and I didn't think about it much at first but upon further inspection I noticed the carpet was wet under the area between the clutch pedal and the kick panel. I'm thinking I might have a leak in the windshield seal but I'll have to check that out.
The relay that was buzzing (pictured below) is relay number 1 on the interior fuse panel inside the vehicle. This relay is labelled "interior lamp" and is not shown in the picture and I have removed it for testing.
Anyone with a 2000 F250 Super-duty had a problem with water intrusion causing weird things like this?
Jun 21, 2021 at 7:38 AM
