does anybody know where auto shut down relay is located? is it inside the driver side fender weld?
Nov 4, 2020 at 4:34 PM
STEVE W.
CERTIFIED EXPERT
It is inside the power center (under the hood fuse panel) mounted on the circuit board if the information is correct. Not a replaceable part without taking the power center apart. However there is also the power relay that does a similar job and it is a replaceable item inside the relay box.
Nov 4, 2020 at 5:15 PM
CERTIFIED EXPERT
Good evening,
I attached the location for you to view.
It is in the power distribution center under the hood.
