i already clean the throttle body sir, already check the vsv and iac valve and all the hoses, its all okay. the mechanic also advice me that to put it back the air conditioner amp. because he said there is no signal came from the air conditioner amp to the ecm. To make the idle up when ac is on.,may hes right sir? On my day off i will do may best to connect the air conditioner amp. and i will massage you sir right away if may works will be okay. Thanks very much for the diagram.
Apr 28, 2016 at 1:49 AM
