Hello, there looks to be two coolant air bleed locations on this vehicle. The one you know about and then one above the coolant (water) pump. I'll post a diagram of the instructions. There are also vacuum kits you can buy for helping to make sure all the air is out of the system. But I think trying to bleed the system by having both bleeders open when the vehicle is cold in the morning will help..
These steps are not in the exact order only because the steps in between are just the different coolant types and closing the drain on the bottom of the radiator.
but I usually do this when the vehicle is cold, that way there's no opening things when the system is under higher pressure and comes shooting out all over the place.
With the system filled, it is still cold and both bleeder screws have been opened and closed in order after the cap is on (and make sure you put the cap on correctly with the arrow facing the overflow tube).
You shouldn't have too much air building up like that. If you still do, I would wait until it cooled down enough that it's not going to shoot hot coolant everywhere, maybe the next day, and run the vehicle with the cap off, and watch for any bubbles or sign that there may potentially be a head gasket issue. That would be the next concern if pressure is building up so high that the coolant hoses start to expand so much.
Here are a couple guides to help:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Oct 23, 2022 at 9:17 AM
