Good morning.
There is a code attached to this issue. Do you have the code number? If you do not, you can have it read at a parts store for free. Once I know the code, I can help narrow the area of failure for you.
Common failures are:
1. TPS sensor.
2. TPS sensor connector damage.
3. Fuel pedal sensor and wiring.
These will need to be checked for any issues prior to replacement.
Sep 2, 2018 at 4:49 AM
