The dreaded REP for GMC vehicles. I replaced the tac module on the firewall, replaced that sensor on the throttle body with the new harness, replaced the sensor on the gas pedal. removed throttle body and cleaned.
Removed mass air flow sensor and cleaned. removed connections on PCM, ECM,throttle body, tac module put dielectric grease on all connections. removed grounds on back of left cylinder head, lower radiator support on left front, on the frame under the drivers side. cleaned all the grounds and reinstalled. made a new ground wire from the firewall to the transmission bell housing. made a new ground wire from the battery to the firewall.
Replaced the ECM today still same problem.
Oct 18, 2017 at 11:38 AM
