Reduced engine power and whining sound
2006 CHEVROLET HHR
270,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MKC22-MICKEAL
So, I am driving down the highway there is a whining sound coming from the engine and the whine is very constant. The whine gets louder as the engine gets faster. But as the engine slows down so does the whine in the engine. I have an older mechanic that doesn't know lot about electronic assisted vehicles and he can't explain the noise nor the reduced power. Also the reduced power started when the noise did and the noise is not always there so there for I don't always have reduced engine power.
Aug 1, 2021 at 4:30 PM
SQM
  • 6,383 POSTS
A vehicle usually goes to reduced power or 'limp mode' to protect engine or transmission components.
Typically a whining noise comes from the transmission.
Now, do you have your check engine light on?
If so you need to get it scanned and see what are the trouble codes.
https://youtu.be/vMwTzURWXmk
Here is a article that explains limp mode in more details:
https://www.2carpros.com/articles/reduced-power-limp-mode
Please let me know what/if are the trouble codes.
Thank you.
Aug 1, 2021 at 5:21 PM
MKC22-MICKEAL
There is no check engine codes related to the problem. I have a scan tool myself. And typically if my hhr goes into "limp mode" it displays the message on my dash where my odometer is. I have had it displayed once but it was when I was cleaning my throttle body and after I reinstalled it, it went into limp mode until I reset my computer.
Aug 1, 2021 at 5:25 PM
It has been a couple of days since you were contacted. Have you made any more progress? Also, is the noise (whining) loud enough for you to record and upload for us to hear?
Let us know.
Aug 3, 2021 at 10:52 PM
MKC22-MICKEAL
No, I haven't made any more progress. Seeing how the vehicle is not throwing any codes and I'm not having drivability problems I use this vehicle to get to work about 2 hours worth of driving everyday driving the morning it drives normally but on my way home is when I have the whining noise. I've posted 2 videos one with the whining noise and lower engine power and one without. But I've also noticed that since the whining noise has started I've been only getting around 22 MPG when I use to get around 28 to 30 MPG.
Aug 6, 2021 at 11:58 AM
There does not need to have any codes for a mechanical issue. This is not an electronic issue, it is mechanical.
This could be a bearing related to the drive belt or something driven by the drive belt.
https://www.2carpros.com/articles/replace-serpentine-belt
It does sound like it is coming from the engine and not anywhere else.
I would start by removing the drive belt and spin all the driven pulleys to see if any make noise.
https://www.2carpros.com/articles/how-a-serpentine-belt-works
Aug 8, 2021 at 3:14 PM
