I did a ls swap into my truck listed above 1500. I got it to start, then I gave it gas then I saw a message reading engine power reduce. I read that it's going to be the throttle body.so I took it off an put another on, that I had that I knew it worked. Installed it and started it up. I didn't see it. i gave it gas then it popped up again. now let me say I do not have the full exhaust on yet. So, I only have the front 2 02 sensors, and my old connector isn't working and it was at first. I have checked the grounds, and it looks good, but I am going to double check. Thank you for taking the time to read this
Aug 26, 2024 at 10:14 PM
