Red thunderbolt, check engine, and ESP light
2005 CHRYSLER 300
150,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DUALARC
A couple of months ago I went to a dealership to change my spark plugs, then my car started to shake once I got my car back from them. After they told me I would need my engine coils to be changed all six of them which would cost around $900.00. I got a trusted mechanic to take a look and he said nothing is wrong with my coils, they just did not plug one in. They tried to scam me, after this event I had all the three lights pop up when I am driving, it slows down my car to the point I cannot go over a certain speed limit or the car shakes uncontrollably. I fix the problem by turning on and off my car (usually fixes the problem). I cleaned out the throttle body and fixed the issue for a couple months. Until yesterday morning when I was driving and the lights turned on again. I did my usually rotten and turned it off and on again, but it almost did not start. Same thing happened this morning, but this time I had to give it some gas to start my car. It is getting colder so that might be it, but I plug in my car at night because if I do not. It will not start the next morning.
Dec 6, 2018 at 10:33 AM
Since the lights are on, you really need to have the computer scanned to determine what diagnostic trouble codes are stored in the system. That will indicate where the problem is coming from. I will say the red light with the thunderbolt is related to the electronic throttle control system. Something may have been disconnected or not reinstalled correctly. Since you just had work done, that is my first suspect.
Here is a quick video showing how to use a scanner:
.https://youtu.be/YV3TRZwer8k
If you do not have a scanner, most parts stores will scan it for free or rent a scanner to you.
Do this and let me know the codes which are found.
Dec 7, 2018 at 10:02 PM
DUALARC
Hi Joe,
Thank you for responding to my question, I took it to a trusted mechanic the day when I asked this because I could not take a chance of my car shutting down. When I took the car to the trusted mechanic it did its usually thing with showing it has no problem at all, but it did turn on the engine light. My mechanic hooked it up to the computer, and said that the engine light was saying there was a problem with the cooling system. He changed out the thermometer, had some problems with overheating, the engine did not receive the coolant for some reason. He replaced it again, and so far so good. Ever since he changed the thermometer I have not been getting the lights. Hoping for the best, it has only been two days since I have had my car back. Once again thank you for taking the time and responding to my question, hope you have a great day.
Dec 12, 2018 at 11:26 AM
Welcome back. I'm glad you got it fixed. I hope nothing happens and it continues running good for you. Also, you are very welcome. We are here to help, so let us know if you have questions in the future.
Dec 12, 2018 at 6:12 PM
