The truck listed above is a 5500 with a 6.4L gas engine / VIN #3C7WRMCJ2LG307278. I had a P0708 code on it December 2021 and performed the below diagnostics on it then was able to clear the code, but it just came back this Saturday. I did the same diagnostics, but the code wouldn't clear this time, any thoughts?
Correction: Scanned computer and found transmission code
for the range sensor circuit showing high voltage - removed
pigtail from sensor and checked wiring and pins, also checked
sensor okay, so remounted pigtail and cleared code then test-drove
to check for code recurrence okay.
Dec 26, 2022 at 8:12 AM
