Recurring misfire with code P1131
1999 FORD CROWN VICTORIA
270,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
TFABE
Had cylinder misfire when purchased car. Replaced spark plugs and coils, ran great for couple days,started running rough.trouble code said misfire #4 and 5.cleaned plugs,ran good for couple days then rough again trouble code said misfire #3 and 4, clean plugs and MAF. Ran good couple days, then rough again. Trouble code said misfire #4 and 5, cleaned, re-gapped plugs, reset PCM.ran good for about 4 days now rough. Trouble code now says misfire #1 and 3, also new trouble code P1131. What do I check or repair/replace next?
May 16, 2021 at 9:02 AM
Good afternoon,
I would check the compression to be sure it is not an internal engine issue.
I would also check the fuel pressure to be sure there is good pressure. Low fuel pressure will cause this issue.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
May 16, 2021 at 12:44 PM
HARRY P
  • 2,292 POSTS
Also if you bought aftermarket coils, they could be the issue. You might try sticking a few of the old ones back in if you still have them. In particular cylinders 1, 3, 4, and 5.
May 16, 2021 at 6:54 PM
