Well if you are like most people who put on a non-factory set of mufflers, you probably like to hear them a bit more. So you step on the gas a bit more often and maybe rev the engine a bit more than you used to. That alone can alter the fuel mileage. Now if you are driving it exactly the same, using the same fuel and everything else is the same, you should get right about the same mileage. I have seen full cat back systems get better mileage than stock and some get worse. 99% of that is due to the driver.
With the mileage you have you might think about cleaning the throttle body, and doing a top cylinder cleaning. Most of the newer engines seem to build more carbon due to the emissions systems and the throttle bores and valves bear the brunt of it. Lot's of videos on those processes out there, watch a few and see if they might help.
Mar 27, 2018 at 4:24 PM
