started noticing a gurgling sound after shutting the vehicle no codes
2002 CHEVROLET TRAILBLAZER
165,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
WHONOT2BE
  • 5 POSTS
I can hear surging in top radiator hose and see fluid rise in expansion tank but there are no code thrown. Temperature gauge usually stays at 210 F most of the time, except recently after driving around seventy five mph on a two hundred and forty mile road trip the temperature creeps about two tick marks up on the temperature gauge. This does not happen until about twenty five miles towards the end of the trip and has happened the last two trips made. I am getting ready to replace the thermostat and lower hose. I have looked at the coolant level and is full and watched to see if any air bubbles in radiator and see no bubbles. Why is the temperature very slowly creeping up? The surge noise is very distinct and you can physically feel in top hose of radiator after turning off the vehicle. The are no visible leaks underneath the car. Any help would be greatly appreciated.
Nov 5, 2017 at 6:11 PM
MHPAUTOS
  • 31,937 POSTS
May be a faulty thermostat or a part blocked radiator, dirty radiator fins restricting air flow, these can all cause your problem.
Nov 6, 2017 at 4:51 AM
WHONOT2BE
  • 5 POSTS
Ok, this weekend after installing a new thermostat I no longer hear the coolant surging through the top radiator hose. After driving for about 30 miles the temperature gauge now shows to be at one tick mark just below 210F. Does this sound correct ? I am wondering if the new thermostat is working correctly now.
Nov 13, 2017 at 2:59 PM
WHONOT2BE
  • 5 POSTS
Also, I notice that the top radiator hose is very hot almost can't touch it bare handed where the bottom radiator is okay to touch bare handed.
Nov 13, 2017 at 3:02 PM
MHPAUTOS
  • 31,937 POSTS
do you know the working temp range of the thermostat you fitted, the temp is stamped on the thermostat.
Nov 13, 2017 at 3:41 PM
WHONOT2BE
  • 5 POSTS
Not sure of Temp range of the thermostat. Purchased at advanced auto parts a carquest p/n:14659
Nov 13, 2017 at 6:16 PM
WHONOT2BE
  • 5 POSTS
Ok according to the advanced auto website this 14659 thermostat starts to open at 190 F
Nov 13, 2017 at 6:25 PM
KHLOW2008
  • 41,814 POSTS
Top hose very hot with lower hose not too hot could mean any of the following.
1. Thermostat not opening sufficiently.
2. Partially clogged radiator.
3. Weak water pump.
2 and 3 are the most likely cause since thermostat has been replaced and the problem occurs mostly after prolonged high speed driving.
Nov 16, 2017 at 12:58 AM
