What is the cost to rebuild 5.0L small block engine?
1995 FORD BRONCO
126,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
EVAN.EILERS
I am very interested in rebuilding my motor out of a 1995 Bronco. It is a 302 5.0. I have watched your instructional videos and they are very helpful, but am still a little concerned about price. Could you tell me how much it costed to rebuild your 5.0 small block 302 in total including machine shop, parts, etc. (everything)?
Jan 7, 2022 at 11:12 AM
SQM
  • 6,383 POSTS
There are a lot of variables when it comes to engine rebuilding.
The cost of components can really vary depending on exactly what will be done. Also, the brand of components will have an impact on the price.
Also, it will be critical to know what exact part that will be replaced and what components will be re-used after cleaning and inspection.
As for the machining of the engine components it will also depend on what task the machine shop will perform.
Also, labor can vary as well depending on the scope of work as of course different shops have different rates.
So unfortunately, it is difficult to come up with a price without knowing exactly what will be done.
Keep in mind that unless you are going for a performance build, it is a better option to purchase a new engine as that will be the cheaper route.
https://youtu.be/iiONenN_MxI
Thank you.
Jan 7, 2022 at 8:16 PM
RYAN L
  • 269 POSTS
Hello Evan,
Thank you so much for watching and using the site! So out the door with parts and machine shop work it was probably around seven thousand or so. But we replaced literally everything and went for a pretty performance orientated build. There was definitively some spaces you could save some cash and just do upgrades later.
Like our previous expert said. There is a lot of variables that affect cost greatly, so it is difficult to give you an exact price on every situation across the board.
Best,
Ryan
Jan 10, 2022 at 2:46 PM
