Wiper will not sweep across the window. i removed the wiper arm and the motor is turning for the wiper, but when i looked inside the wiper arm, i saw that the the groves that slide on the armar wore. I tried using duct tape , didn't last, as when you use the wipe , it wears down the tape. Even tried to tighten the 1/2 " bolt a little tighter,and worked for while,5-9 sweeps, shen stops. I was thinking of using JB Weld, but was a little leary that if i had to replace the motor, this would be frozen on the arm and would never be able to get the wiper off. Open for ideas. thanks
Feb 7, 2021 at 10:57 AM
